Hi Guys -
Cranking on the body work now. PO welded floor patch panels over original floor. Driver side has very small, minor rust hole, passenger side is fine but they welded in a patch panel on top of it anyway. Cleaning up a messy bondo job around the patch panels.
I bought a new one piece floor panel and intended to cut everything out and weld in new but second guessing it and really not sure I need to.
What would you do? Options as I see it:
1. Leave it as is and simply linex or raptor line the underside.
2. Cut it all out and weld in new floor.
3. Weld in new floor on top of existing floor and linex or raptor line bottom. Essentially 3 layers of sheet metal. Is that bad?
I know this sounds lazy but the floor is not as bad as I thought. Is it bad to weld another floor on top? Thinking it would act as a good sound and heat shield.
Appreciate people's thoughts.
