Tranny dropped
ledslinger29
While I'm rebuilding the motor. as you can see, after 48 years leaks have gotten a little hard to zero in on. Gonna clean all this up and put new seals on all of it
muskrat
sure do. they were fun to work with getting the TC back in.
B RON CO
Statesville, NC
Hi, I thought there were 13. A coat of grease will hold them in place. If they don't fit and fill up the race you don't have all of the bearings. Good luck
Smedley
Snohomish
I just did the same thing and it was confirmed by several on here that there should be 13.
I cleaned and painted and then brought to a local shop and they replaced all seals and put T-case and transmission back together. About $200.
Will
migs
Nice! that's some grade A rust prevention right there, you sure you want to get rid of it?;D If you were lucky it would have flung more of it up to the floor boards...it really helps 40 year old seat belt bolts to come right out.%)
Toddpole
Get all that grease and dirt off and she'll pick up 2/10s in the 1/4.
