Almost ready to start sealing the frame and underbody, have a bit more clean up work todo... lesson learned.. next time iam taking the body and frame in to have done, its cool to get to know every crevice of the bronco but I could have used the time to concentrate on other bits that need to be done.. but oh well - onward and upward
Anyway i have started thinking about the rust spots that need to be repaired and took a few photos of the problem areas. I have a good idea on what to do on most of the areas however a little advice is always welcome!
I'm fighting the urge to get the suspension together and then stripping down the tub and just get it blasted patched and then painted... but sadly its not in my budget right now... so reluctantly it can wait.
Anyway, here is a breakdown of what I have to patch, replace or ???
The front side walls of the engine bay are pretty obvious, patch them up (after i get the frame back on the body). Pretty straight forward.
Drivers Side
Passenger Side
Next up is the front side front door pillar post on the drivers side. I was thinking the whole post would have to be replaced. But maybe i can patch it and make sure i seal the inside real good with a decent rust inhibitor? i tried to get some pics up inside.. the rot really doesn't go up too far and I couldn't find any underneath or on the hinge side of the post... what would you guys do?
Drivers side pillar.
Passenger side door pillar...
My next areas are the two rear lower corner panels, one had been patched or partially patched as it turns out.. a little bondo on the bottom of the tail light panel.. feel right out when i hit it with the needler.. anyway thinking i should just make up new sections for each side and bend them into shape.. however it might be better to just replace both ends? thoughts?
Drivers side
Passenger side
and so the last area(s) the quarter panels... the passenger side seems to be the worse bit. Not sure what to do besides to go and replace both panels.. which would really be a bummer since no other part of the quarter panel is rusted and Iam trying to keep the truck as original as possible.. anyway.. advice?
Drivers side quarter panel.
Passenger side quarter panel
Anyway those are my areas to work on... i know compared to some rigs its not that bad.. but I'm not a body guy and seeing how iam restoring this truck back to original and I want to make sure its done right. Any advice is welcome
I expect I can seal the frame and most of the body and then tackle the patches once the suspension is back together...so i have some time...
