allenfahey
- Mar 18, 2004
- 2,672
Get in touch with Broncitis here on CB. He lives in York and has alot of parts.
Also, am I correct is assuming the black switch to the left of the radio was cut in there, but that otherwise all switches are stock and it's an otherwise uncut dash?
Thanks!
Looks pretty solid. I would get after the bottom side with a wire wheel/brushes and get some chassie saver/por 15 on it. It is labor intensive but dosnet require much skill and wont cost much $. It has been a southern truck that probally has not seen much moisture. Once you start useing it around you in the upper north east it will start rusting faster. Once done the bottom will be sealed up and you could start with the body. Mabey you could tape off the seams and grind/ blast out the seems then paint a stripe or something temporaily that looks decent till you are ready to spend the $,$$$ to paint. Good luck to ya and have fun, thats what is about right?
Franko - what does that switch do? The black plastic switch in that location on my truck appears to do absolutely nothing!
Thanks for the info. Which areas in particular did you see that looked really bad? Also, not a bad idea on the stripe. I don't need it to look perfect, but the primer/bondo/halfway through doing some body work look isn't too appealing either!
This is our 3rd car and will likely be more of a weekend cruiser, fun car. My wife's legacy wagon will pull snow duty for us, so hopefully the EB won't be too exposed to the elements.
Again in keeping with the theme of 3s, I found 3 more things I need to buy: new ignition switch, heater control valve and new oil pressure sending unit. It'll be my cheapest total yet from bronco graveyard!
