28 grand for a truck with California plates, spent a year in Idaho and now is in Michigian. Make sure it is properly titled, title, registration, frame numbers and glove box tag matches before you even think about ploping down your money on that thing. Nothing on that truck says to me plop down 28 grand on that truck. Needs far too much work to be anywhere near that price. Look at every picture and check off everything that is missing or not right. Far too many things add up to big amounts of cash. You have Bronco fever, if you must buy that thing get your ass out there and see it first hand. Drive it first hand. Then decide if you still want to plop even more cash into that truck.
Previously mentioned registration trail in question
The interior looks like it could be refreshed, tired
What is with the patch job on the dash for the radio?
Missing brake warning light in dash
Hood seal missing from fresh air intake for heater
Missing windshield washer res top, got to buy the whole thing to replace
No hoses hooked up to the Heater, core probably is bad>leaks
Leaking brake fluid on the inner fender from the master.
No cables for the rear parking brakes, not hooked up
Patch job(s) around where wire harness enters the engine compartment.
D30 front axle with 35" tires, kind of pushing the limit there
Pictures do not show front disc brake conversion as advertised, still drum
Bolts welded to frame, for maybe a missing skid plate for transfer case?
Front bumper/push bar weld to frame
Inner fenders have been patched
Lots of silver paint all over engine compartment
Looks like the frame/axles were spray bombed
Age of tires is always a question
I would recommend that you keep looking...
