Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 12/10/17, 09:49 AM   #346
Bferrari
Bferrari's Avatar
Nipomo, CA
Originally Posted by No Hay View Post
BTW, beautiful ride! May I ask where you found the boot for the twin sticks? They look perfect (less rigid) than I've seen. Thx!
Thanks, we made the boot from scratch. Basically made a ring and sewn some leather.
Bferrari is offline   Reply With Quote
Old 12/10/17, 11:55 AM   #347
boonz28
boonz28's Avatar
Wherever ya go, there ya are
Bakersfield
Originally Posted by Bferrari View Post
Question for you all, anyone have issues with air trapped in your cooling system? After 700 miles, had an issue with The rear cylinders getting hot. Needless to say, motors coming out, I'm thinking of stroking it since I've got to go through the bottom end.
Man, I'm really sorry to hear this Ben, i know the pain of having to pull an engine shortly after a fresh rebuild.
You said it got hot, what exactly happened to cause you to pull the bottom end back apart?
'Ol Blue Daily Driver - 2000 explorer 5.0, 3spd on the floor, 3 1/2" WH suspension lift, 2" body lift, Hydroboost, front disc brakes, 4x4x2, more to come...
http://classicbroncos.com/forums/sho...d.php?t=211047
boonz28 is offline   Reply With Quote
Old 12/10/17, 01:00 PM   #348
Bferrari
Bferrari's Avatar
Nipomo, CA
Evidently there is an issue with small block fords where air gets trapped in the block and will overheat a cylinder. Gets hot, piston swells, then galls the cylinder. I've built dozen of small block fords and have never had this issue, nor even heard of it. In talking with my machinist, he says this happens more than you think. Enough so that I guess there is a technical service bulliten on it. Now that it has happened I bought the coolant tool from robinaire, and am going to be very paranoid getting coolant into this thing.
Old 12/11/17, 06:23 PM   #349
boonz28
boonz28's Avatar
Bakersfield
Yeah i bet, man that stinks! I had a piston seize up and break on my last build (also ran good at first and then went bad). No real indication as to why and my machinist was also unsure. I've probably got somewhere close to a thousand miles on this second rebuild and so far everything seems to be good. I hope i don't run into similar problems.
Did you seize or break a piston then?
It sounds like you already tore the engine back apart, if so how much did it tear up?
Old 12/12/17, 01:46 PM   #350
englewoodcowboy
Lick Creek Restorations
englewoodcowboy's Avatar
"The Duck"
Ceres, VA
I had the same thing happen to the red ranger we built. It is back in our shop and about to go home with a fresh motor. This one started by cooking #2. My machinist said using stock pistons this is more common to happen vs aftermarket due to the friction preventers in new piston designs, they cannot hot and swell but less likely to gall. Because of this, even if the motor is well within specs we will now always cut them .030 over and put in new pistons. Fortunately for me this is the only motor we reused the stock pistons in and the only motor we had an issue with. Live an learn I suppose and education never comes cheap. I have the robin air tool but it was broken at the time I loaded this motor, it has since been repaired and will be used on every motor from here on out.
BoxWood Green Poly '73 (o===o) 347 Stroker, FiTech Go EFI, Explorer Serp,2.5" Duff SL w/Bilsteins, Duff TQ Tamer, AOD, Hydroboost, TrueTrac LS Front & Rear, 4.88 gears, 35" BFG KM3, F150 Disc Brake, Factory PS, Family Cage ctsy Nick's Trix, AC, Stereo, PWR Windows, Locks & Steps My Build.
englewoodcowboy is offline   Reply With Quote
Old 12/19/17, 12:44 AM   #351
Bferrari
Bferrari's Avatar
Nipomo, CA
Not too sure, haven't pulled it out yet. I am hoping to in the next week or so. I'll let you know the details when I get it out.
Old 12/19/17, 09:20 AM   #352
904Bronco
904Bronco's Avatar
So many Ford's, so little time...
Morgan Hill, CA
Sorry to hear this Ben, I experienced something similar with my 68 build. Ended up pulling a motor with a few 100 miles on it, Certainly no fun at all. Machinist could not figure out why the cylinder walls were scored... But he made good on it.
1967 Poppy Red U15 Lubr... soon to be 96 Explorer EDIS and NV3550
1971 Grabber Green U15 Lubr... 2000 Explorer EDIS and 4R70W
2016 Shelby GT350 - Race red
2002 F250 Superduty 7.3 202K and still going!
1996 Saleen Mustang 125K... Project car
904Bronco is offline   Reply With Quote
Old 12/20/17, 05:58 AM   #353
broncoitis
broncoitis's Avatar
R.I.P Roscoe and Daisy! Miss you so much!!!
North Jersey
Wow, sorry to hear about that misfortune Ben! That really SUCKS to put it mildly. Well hopefully it goes back together this next time without incident!
Happy holidays and a healthy new year Amigo for you the family and the Bronco!
Rob 1970 Bronco: Rebuilt 302, EFI, Exp Serp, Vintage Air, Cust Console, Corbeau Seats, etc...
Build: Springtime or Bust!!!
broncoitis is offline   Reply With Quote
Old 04/27/18, 01:09 PM   #354
Bferrari
Bferrari's Avatar
Nipomo, CA
Back in the saddle! Motor is back in, now time to drive the wheels off of it! So happy to have it back together.
Click image for larger version
ID:	450530Click image for larger version
Old 04/27/18, 01:28 PM   #355
tasker
all knowing of nothing
tasker's Avatar
It's a jeep thing? you're all morons
The granite state
be proud!! looks so good!!
tasker is offline   Reply With Quote
Old 04/27/18, 01:57 PM   #356
bronkenn
I believe you, thousands wouldn't
Southeast Ohio
Looks real nice. I'm not a cut Bronco fan but if you do it that is definitely the way to go. Great job. Ken
bronkenn is online now   Reply With Quote
Old 04/27/18, 08:28 PM   #357
broncobsession
Not a bronco guru
broncobsession's Avatar
All Over the Place
Ridiculous. Meticulous attention to detail. Have fun driving it!
Always looking for the next project.
broncobsession is offline   Reply With Quote
Old 04/28/18, 05:19 AM   #358
Howard2x4x4
Howard2x4x4's Avatar
Holland, MI
Truly a thing of beauty! Great work, Ben! Howard in beautiful west Michigan
Howard2x4x4 is offline   Reply With Quote
Old 04/28/18, 11:08 AM   #359
rydog1130
rydog1130's Avatar
Bronco Math: time+money=bronco and if time=money then money+money=LOTS OF MONEY
Kalamazoo, MI
Attachment 450530Attachment 450531
Awesome bud! glad you're on the road!
1968 Bronco, 289, dana 30, C4 auto, stock ps, MSD ready to run ignition, centech, desert khaki....everything else stock
1970 Bronco 302 3 spd, Koenig PTO winch
1990 AM GENERAL HUMVEE
2009 Dodge Challenger R/T
2008 Honda Element (aka Bronco Concept)
rydog1130 is offline   Reply With Quote
Old 04/28/18, 11:28 AM   #360
broncoitis
broncoitis's Avatar
North Jersey
Good job AMIGO! Truck looks GREAT!
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright 1996-2019 All rights reserved. Privacy Statement
Page generated in 0.34340 seconds with 61 queries
