Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 04/27/18, 08:09 AM   #1
sandersnc
Adding accessories
Any suggestions on the best way to add extra accessories controlled with the ignition switch? Thanks
sandersnc is offline   Reply With Quote
Old 04/27/18, 10:08 AM   #2
JaxLax
JaxLax's Avatar
Some Dude
Jacksonville
eBay: JaxLax02
Grab a single pole relay and an aux fuse panel.
Set it up so the panel isn't hot until the ign hot is switched.
It'll be a lot easier than splicing off each time you want to add something and the wiring can be done a lot cleaner.
Red 77: SOLD
Green 77: SOLD
Ginger 77: OUT OF THE GARAGE AND DRIVING DAILY
Want To Buy - Parts For Sale
JaxLax is offline   Reply With Quote
Old 04/27/18, 11:23 AM   #3
ObscureMachine
Seatbelt Orifice Officer
ObscureMachine's Avatar
Down the hall, left at the gator
World Headquarters
^x2^ I used a relay that sends a load to a Blue Sea fuse block, then ran everything off of there. Mine is double sided so I run one side always hot, and one side ignition hot. Works great. I run my electric fuel pump and a few other things off of it.
Rebuilding almost every part of the "Complete Restoration" ButtStank Bronco. No Worries.
Facebook - JHO Wood Works
My Etsy Store
Instagram @jhowoodworks
ObscureMachine is offline   Reply With Quote
Old 04/27/18, 11:45 AM   #4
DirtDonk's Avatar
San Jose, CA
x3 what they said.
It's the only way to add more than maybe one or two small accessories and keep the switch living a long and prosperous life.
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is offline   Reply With Quote
Old 04/28/18, 07:43 AM   #5
charlie6976
Grand Coulee WA
I did this set up, but put a fuse in front of the relay that doesn't exceed the rating of the relay or the rating of the (new) aux fuse panel. Say you put a 25 amp fuse in each circuit, each circuit is fine until enough circuits come on and go over the panel rating.
A panel that includes grounds can be real handy. Fiberglass body.
charlie6976 is online now   Reply With Quote
Page generated in 0.31322 seconds with 63 queries
