Need Explorer fuel o'rings, Pressure and return
904Bronco
San Martin, CA
I guess I used up my supply from Ford I bought years ago...
I tried calling parts at my local Ford Dealer, the Gal I spoke with couldn't help me without a VIN. Christ, the rig has been crushed over a year ago.
Dug up the VIN and gave the part# that was still on the fuel rail extension. Not available :-X:p
So I came up with a few Dorman numbers on a Google hunt, all special order...
So does anyone have the correct numbers for original Ford Part# or a replacement aftermarket suppler part# for the Viton fuel line o'rings... the 5/16" and 3/8" size. (And knows that they work)
I appreciate the help. Doug
Theses are Not injector o'rings, or Regulator o'rings...
Rustytruck
all else fails you can get viton o-rings from Mc Master Carr the only hope someone local stocks might be a local Napa since they supply local garages.
fordguy
i found o-rings for injectors on rock auto, you might check there, they have a lot of smaller parts listed if you look under explorer
toddz69
Ping 1sicbronconut on here - he's a longtime Ford tech.
Todd Z.
I got a supply of odd sizes and styles at Winchester Auto Doug.
Unfortunately to your other question, as you know I have not tried them yet, so don't know if they're correct or not.
But they were in stock in their "fuel repair kit" supply box.
904Bronco
904Bronco
San Martin, CA
Another Ford Parts guy here on the site is investigating for me... so far the o'rings are not listed separately... Hoping a Fox Body mustang will work or at least have a listing...
Thx for the replies...
904Bronco
904Bronco
San Martin, CA
904Bronco
904Bronco
San Martin, CA
Closing this up, hope it helps the next Guy or Gal...
They were the correct o-rings...
That part is done, moving on to the next thing.
