About to weld on some new lower quarters (and rockers). I removed the auxiliary tank but left the main rear tank. Should I remove the rear tank or am I being a bit too cautious? What would you do?
Yeah, guess it does not pay to cut corners. I have a full tank of gas in there and didn't want to wrestle with it but better safe than sorry. Was just curious if others removed their gas tank before welding.
If it wasn't for the filler neck being there and open I would say you could leave it on, but with welding on that side remove it.
No sense taking a chance of a spark getting into the fuel vapor.
Panel adhesive and self tapping screws across the top. Weld on both ends (striker post front and to tailgate housing in the rear). By far the easiest and best IMO. Just did it. You won't get close enough to the filler neck while welding to be dangerous. Well, no more dangerous than creating the occasional unseen spark when you removed the lower quarter. You should drain the tank though. But anything can happen I guess so use your best judgement.
Just my 2 cents here. Even if you drain the tank remove it. A tank full of vapors is more dangerous than a tank full of fuel.
Good luck with your project!
Be very careful welding with gas in the same room. I never have gas containers in the shop. My neighbor was welding in his shop about three years ago and had some gas cans on the other side of his building and the fumes crept through the garage as he was welding and ignited. He was burned very badly and died a few days later. Very bad deal. Keep the flammables and welding separated. Ken
