1974 Sport Survivor...Next steps and recommendations needed.
Mtymse63
Mtymse63
Newbie
LUBr LuvR - thanks for pics and information. Wasn't able to pull up thread but I know where I can research. Really thinking I may purchase some Rust Freeze and give it a try a short the areas I want to address have seams.
75Denver
I'm not sure your intent and use until replacing pans (if ever), but I used EvapoRust purchased from Summit Racing and was very pleased with the final outcome. It was very easy to use and a quick, easy, eco-friendly cleanup. It revealed more rust than I though I had in the pans...no holes at the start to small pin holes after application. I live in the NV desert and don't plan on using it in the winter snow so I never covered up the ugly rust marks with fresh paint (didn't want to hide anything).
Here's the start/finish pics but by what I can tell, stopped the progression of it and in some spots completely took it dow to bare metal.
Mtymse63
Mtymse63
Newbie
75Denver - nice work! Never have used EvapoRust but have seen it referred To often. Per the comments above and my experience, Ospho does a great job but not good on paint.
How does paint react to EvapoRust? Contemplating not painting as well which is what I've done in the past. After removing rust I've usually sprayed with clear coat by Spray Max and had very good luck. Like you, I don't want to hide anything.
75Denver
As long as you wash it off with warm water and dry it before covering with the floor mat, the paint is the same as before starting. If you want to be extra diligent, a second wash wouldn't hurt. I couldn't imagine a bio-safe product really damaging anything even if you didn't clean it as well as it recommends. All I found was a dried amber film at the end needing a little elbow grease. Buuuut, if you want, I can save you a step in the reassembly and buy that floor mat off you;);D
Mtymse63
Mtymse63
Newbie
From what I've heard, I can get close to "Ooone Miiiillllion Dooolars" for the mat, lol. Mat is in pretty good condition and trying to preserve as best I can.
