Oklahoma City Area
Shalackin
Norman, OK
Anyone here in the OKC area? I need to find a shop that can work on my Bronco that is trusted. Preferably in Norman or the south side. Not just mechanical, but also restoration type work. So they need to be able to handle both.
bowhunter
Not sure about OKC....but Bailiebilt is here in Tulsa. He's a good guy, very capable and would probably come pick it up for you if you can reach an agreement with him. He can do all the things you've listed and more.
Shalackin
Shalackin
Norman, OK
Thanks! I will keep that in mind. sure would like to find a trustworthy resource here in OKC that I can drive it to.
sprdv1
REBEL
Skiddy on here is in OKC area.... and 2Broncos2Go .....
Skiddy will help out I'm sure... :)
Skiddy
what all are you needing done, Mr. Dixon in AR does great work
sprdv1
REBEL
True. Not that far away either
Would be a great place for you to get a work done
Shalackin
Shalackin
Norman, OK
What I have on the list now is....
Fixing or rigging the vapor canister
Spray inside with lizard skin
Undercoating
Get seats installed correctly
Install seat belts
New bushings
Roll bar with soft bikini top of some sort
Radio and speakers
I don't know much. Not a mechanic. So will take suggestions from whoever works on it. I don't mind doing a bit of this myself but don't know where to begin on some things.
Skiddy
the only thing I think that maybe a little hard would be the inside and undercoating. inside not too bad but you have to remove everything and clean and clean
Shalackin
Shalackin
Norman, OK
The hardest part at this point seems to be time. Some of this stuff can wait til i get some free time to do it. But some of it I just want to pay someone to do so that I can get her going and enjoy it. Which is why I was looking for someone remotely close that I can trust to do it right.
sprdv1
REBEL
Gordon Bailie is in Tulsa area... Maybe reach out to Bailie Bilt see what you can work o ut
okorangebrnco
I am usually in the OKC area a few times a month. I could help you out on the weekends if you would like to learn more.
