Gas tank install turns into full build....
J
Joe473
Good news track bar mount was actually fine. 3 or 4 shots with a sharp chisel and the crappy brazed washers came off revealing very good mount holes. One less thing to do until I decide to lift or not.
Sent from my SM-G900V using Tapatalk
J
Joe473
Been working weekends at my real job but have been putting in some time on this. Got frame wire brushed and primed with KBS. Also did primer on front clip and underside after a few days of scrubbing. Also did KBS on backside of rear quarters behind seam.
Good news Vin number still readable. Just going to clear over that.
J
Joe473
You will have a new truck when you are done! That is looking great!
Thanks for the kind words. Hopefully the weather drys out and I can move forward with chassis paint and seam sealer!
maup
wow Joe strong work...
I plan to turn a blind eye to the bodywork when I install my tank and explorer 5.0...
J
Joe473
With seam sealer applied and 2nd coat of primer. I tried to match the horrible factory sealer application best I could!! SEM self leveling flowed out similar to factory stuff.
dave67fd
Nice work Joe, cant wait till i'm at this stage...Making good progress in short time.
J
Joe473
Finally had some good weather friday night and got some color on it. Due to recent weather delaying paint and 5 week delay from vendor on rotating assembly plus bad connectinf rod out of box my truck is not making it to Carlisle as planned. :(
J
Joe473
Bahama blue '71. Napa mixed so could be a little off. Just cleaning up engine bay
J
Joe473
Short block has been assembled. Add hiccup with brand new connecting rod being bad from Vendor. Getting valvetrain together after work.
Questions is would you paint or clear coat a brand new timing cover?
Same with aftermarket intake. I would like to paint but how well does engine paint adhere to aluminum?
broncoman1972
On my Explorer swap I used aluminum look engine paint on the brackets, timing cover, upper and lower intakes. They were painted over 2 years ago, but only driving since November, and still look good.
Sent on the fly
mdside
PNW
Looks great!!
I will be happy when my rigs looks like your before, and extremely happy if my progress starts to look like your recent progress pics!!
J
Joe473
Gauge cluster came back from Kevin and I did my 4100 rebuild this week. Hopefully 48 primary and 55 secondary jets work for a mild 347.
J
Joe473
So in prep for my M5R2 install I noticed bolt holes are not big enough for 7/16" hardware. Anyone else have to drill the M5R2 bellhousing for the 7/16 hardware?
J
Joe473
Yes you do. Check the dowel pins too.
Thanks sir, pics helped a bunch on the master cylinder. Ended with a 91 f150 master. If you zoom in you can see the brace I made for firewall.
Slednut10
Guru? That's funny!
Nice work, Joe. Definitely prettier than mine!
On the subject of the clutch MC, member JSMALL had an issue using that series of MC, namely a heavy pedal and little clutch control. He ended up going with a later model out of a 95 F250. Earlier ones have an .880 bore while the later ones are .708. Mine is the later one and I like the feel and control. I never experienced the earlier one and can't speak as to how it feels.
http://classicbroncos.com/forums/showthread.php?t=253302&page=3 see post 32
J
Joe473
Thanks for the compliment and the heads up! I tried getting the later one and it had bottom hose vs the hose out the front like yours had. To find one with hose out front I had to go earlier. I'll check part numbers later in the week and confirm bore size.
I'm also curious if J small had heavy duty pressure plate. The slave cylinder part number is consistent between 150/250 and across many years.
