Godwick
So... long story short, with my old tires (32" Mts) my camber was off so badly (+) that it wore the outer tread of the tires very prematurely. I recently got 32" ATs and in an effort to prevent the same thing from happening, took it to an alignment shop.
The shop adjusted toe, and took readings on the bronco (which I can't find at the moment), but didn't touch the camber b/c they needed bushings to do so.
Not wanting to fork over the $500 to have them redo it all again and install the bushings, I bought myself a camber level and the bushings and went at it today.
Here's the thing:
To measure camber, I took the front wheels off, jacked up the front end, made sure (with tape measure) that both sides of the front end are level, and then used the camber level on the outer rotor.
I gave the passenger rotor +1 degree positive camber, then buttoned it up and lowered the truck.
Thing is, if I measure from the hub itself, I get a NEGATIVE camber reading. If I measure from the top of the tire, I get a very positive reading. So... what gives? Could the wheel be bent? Is that typical? How do I compensate for the top of the wheel if the top of the rotor reads +1 degree?
Any tips appreciated!
Here's the thing:
