HotWheels
you are correct. black wire to housing and all will be well.
71 BRNCO said:Now that everyone has had this mod for awhile....is everything still working perfect and only one person has made a coment about it being loud. Anyone else noticed this. I am leaving at 12 to go and buy the parts.
so I just use a dremel to enlargen the hole and put the new motor and cage asembly into the heater dril the holes and screw it in. sound like the electrical setup is the same as stock. a few more thoughts please
kyle
cracker said:I have got my entire tub dismantled and removed, time for another upgrade! If I keep watching this list any longer, it will take me forever to get the EB back on the road, because Iwill keep "upgrading" it.
Mark Troy said:Kidney, what alternator are you running. Don't tell me it's the stock 60amp slug!
Go back to the parts store and get yourself a drop in 100 amp like mine. Cost $60.00 - You'll be able to run that heater motor on high with no problems.
check out this thread
http://www.classicbroncos.com/forums/showthread.php?t=40332
Hey kidney, its not even a project, you can do it during halftime of a football game.Kidney said:Guilty as charged ......That is actually my next project. The weather has been pretty crappy so I havent had a chance to get around to it.
Mark Troy said:Napa blower motor # 455-1039 = Advance Auto p/n: 35587 for $20
Napa squirrel cage # 655-1406 = Advance Auto p/n: 35602 for $14
That's less than half the moolah ($$) that napa wanted.
Brewbro21 said:Hotwheels where are these other upgrades you were talking about? I couldn't access your link.
Mark Troy said:I finally did this upgrade last weekend. I no longer think about getting an aftermarket heater like the heatercraft. This is a wonderful upgrade. Thanks Hotwheels! Where'd you get the idea? Anyhoot I thought I'd add some more photos to this thread.
As you can see, I did a complete rebuild with new seals and heater core.
The wife is away on a trip so I can use the dining room for Man/Bronco purposes BTW my motor was made in Canada and is not a Siemens brand, and a lot less expensive than Napa's Siemens unit.
Yeah I checked that also. The fins of the squirrel cage are directed the same as the original. I want to check the rotation of the original motor - the new one turns counterclockwise (looking at the motor shaft).cbfomoco said:for the pic it looks like it spins backwards btu it could be me would that be a problem or is ti why it works so well ? thanks also does napa sell the new seals for the heater or is that a bronoco house thing. thanks
Mark Troy said:The wife is away on a trip so I can use the dining room for Man/Bronco purposes
i have the old 60 amp alt and i run the upgrade heater motor and halogen headlights. it was slowly dagging the battery down until i made sure i had a good ground between the bat and body and the engine and body. it works fine now. when i need to replace the alternator, i will certainly go for a bigger one.
if there is a reason i dont aways run the high setting, it because its so loud.
